control-bar_audio-track-controls_audio-track-button.js
 * @file audio-track-button.js
import TrackButton from '../track-button.js';
import Component from '../../component.js';
import AudioTrackMenuItem from './audio-track-menu-item.js';
 * The base class for buttons that toggle specific {@link AudioTrack} types.
 * @extends TrackButton
class AudioTrackButton extends TrackButton {
   * Creates an instance of this class.
   * @param {Player} player
   *        The `Player` that this class should be attached to.
   * @param {Object} [options={}]
   *        The key/value store of player options.
  constructor(player, options = {}) {
    options.tracks = player.audioTracks();
    super(player, options);
    this.setIcon('audio');
   * Builds the default DOM `className`.
   * @return {string}
   *         The DOM `className` for this object.
  buildCSSClass() {
    return `vjs-audio-button ${super.buildCSSClass()}`;
  buildWrapperCSSClass() {
    return `vjs-audio-button ${super.buildWrapperCSSClass()}`;
   * Create a menu item for each audio track
   * @param {AudioTrackMenuItem[]} [items=[]]
   *        An array of existing menu items to use.
   * @return {AudioTrackMenuItem[]}
   *         An array of menu items
  createItems(items = []) {
    // if there's only one audio track, there no point in showing it
    this.hideThreshold_ = 1;
    const tracks = this.player_.audioTracks();
    for (let i = 0; i < tracks.length; i++) {
      const track = tracks[i];
      items.push(new AudioTrackMenuItem(this.player_, {
        track,
        // MenuItem is selectable
        selectable: true,
        // MenuItem is NOT multiSelectable (i.e. only one can be marked "selected" at a time)
        multiSelectable: false
    return items;
 * The text that should display over the `AudioTrackButton`s controls. Added for localization.
 * @type {string}
 * @protected
AudioTrackButton.prototype.controlText_ = 'Audio Track';
Component.registerComponent('AudioTrackButton', AudioTrackButton);
export default AudioTrackButton;
